Old 09-29-2021, 09:21 PM
MitchJ MitchJ is offline
Default Battery for a GT3200
Hello, I just ventured into the world of the 3000 series with a GT3200. I found a nice unit, with only 344 hours on it. I noticed the battery is original and a bit sluggy. What is the group size etc. of this top post battery? Thanks!
Old 09-30-2021, 05:34 AM
Mitch, I believe they are a group 51 battery. Just make sure it has the terminals in the proper location. I have changed the battery connections on some of mine to just use a standard L&G battery with no issues.
Old 09-30-2021, 08:45 AM
Thanks I thought it looked like that one $. I’ve got same expensive one in a JD
Old 09-30-2021, 04:05 PM
CubDieselFan's Avatar
I did the same as Oak in my 3235 and have had no problems.
Old 10-02-2021, 11:24 PM
Ozcub's Avatar
Ozcub Ozcub is offline
I would suggest either a Gel or Calcium type as they are less susceptible to vibrations and being shaken to bits
Oz
Old 10-03-2021, 11:33 PM
Ken41's Avatar
Ken41 Ken41 is offline
Oz
I will have to try to remember that. Plus the fact that the acid splashes around. I put gel in my boat when I had it.
Old 10-04-2021, 07:55 AM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
I've had no problems using the $40 L&G 350CCA batteries from farm and fleet. Usually last 4-5 years.
JD x475
Old 10-04-2021, 10:05 AM
Same here.
Use 'em in all my Cubs.
Old 10-04-2021, 10:27 PM
I’m actually pretty impressed the original battery still in there and it seems to be working fine it has 2009 stamped on it.
