Old 09-19-2011, 09:38 PM
cub1782's Avatar
cub1782 cub1782 is offline
Default 1782 blowing fuses
My cub cadet 1782 keeps blowing fuses when I start it or when use the glow plugs. I can't find a bare wire. I have blow over 25 fuse trying to figure out whats wrong with. The starter will spin sometimes. I don't know please help me!!!!!!!!!!!!
Logan Pfeiffer
1986 cub cadet 1606 w/ spring assist, cat 0
1974 cub cadet 149 sleeve hitch
1984 gravely 5665 professional
1979 gravely 8122
1979 gravely 8102
2000 Exmark lazer Z
1978 international 184
Proud to be a member of the FFA
Old 09-19-2011, 10:09 PM
LarryW's Avatar
LarryW LarryW is offline
I wonder if a glow plug is bad? Not sure if that possible but if the wires are good then it must be the thing trying to run is drawing to much amps.(glow plugs or starter solenoid ) Maybe there is a short in the key switch. I have never seen it but.... Not sure how your fuses are but my fuse in the 1872 is a glass one and it came loose once and hit the metal hole in dash it goes into and blew. I blew a few before I figured that out. Good luck. Electical shorts are the worst to find sometimes.
Cub Cadet 147 2050041u340160
Cub cadet 129 main mower
Cub Cadet 1811
Old 09-19-2011, 10:12 PM
LarryW's Avatar
Also, I was just thinking, assuming your switch is off, lights/run,run, start. Maybe you have a light issue and its blowing when you switch crosses from off position to start? Just an idea?
Cub Cadet 1811
Old 09-20-2011, 01:23 PM
cub1782's Avatar
Larry,
Thanks , It just maybe the lights,because the PO for some reason cut the old head light wires. I , wired them back up and guess what now its blowing fuses.
thanks
Logan Pfeiffer
Logan Pfeiffer
1979 gravely 8122
1979 gravely 8102
2000 Exmark lazer Z
Old 09-20-2011, 03:56 PM
scleve scleve is offline
That is great! Much easier to rewire lights than chase down a short.
Old 09-20-2011, 06:56 PM
LarryW's Avatar
Sweet, I hope it is! Lets pray its the lights! lol
Cub Cadet 1811
Old 09-20-2011, 07:34 PM
cub1782's Avatar
well, its not the lights. I think it is the fuel selion(fuel shut off) I push it in and runs great. I let go it shut downs and blows a fuse.
So, I called the cub dealer they tolled me it was unavalibe, the kubota dealer had to check it out and I have to call tommrrow. If they don't have I'll have to get used.
Logan Pfeiffer
1979 gravely 8122
1979 gravely 8102
2000 Exmark lazer Z
Old 09-20-2011, 08:15 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
I don't know if the fuel shutoff solenoid is available from a Kubota dealer. I just looked in my parts manual to see if I could help you out and maybe even find a newer part number. All the Kubota parts I see in there have a "KB" prefix. The fuel solenoid has no prefix and is a cub cadet series number of 759-3544. This number is probably superceded by a newer number.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 09-20-2011, 08:18 PM
FrankF3's Avatar
BTW - My cub cadet dealer has access to a system that has listings of obsolete/nos parts that are still avail at other dealers. ask yours if he has access to a system like this. It's worth a shot.
Old 09-20-2011, 10:26 PM
cub1450's Avatar
cub1450 cub1450 is offline
Logan,
Why don't you try running a wire straight to the battery from the fuel solenoid.
Remember thats what I had to do to the red rally.
Jed
1975 1650SGT Work In Progress
1974 108 (Mint) #510358
