Old 04-04-2012, 06:07 PM
Just for giggles,swat the voltage regulator with a screwdriver handle or take the cover off and see if one set of points on the cutout coil is stuck closed.
if it is, that was your problem
Old 04-04-2012, 09:07 PM
nikster's Avatar
nikster nikster is offline
Now you disconnect the positive cable from the battery, then connect a 12 volt bulb between the cable and the battery post.
The bulb will light up.
Start disconnecting things until the bulb goes out.
When the bulb goes out, you have found the component that needs fixed/replaced.
Now that's clever!
1st. I'll try smacking the voltage reg., see what happens. Then maybe put the voltage reg., from my # 109. Then I'll smack the snot out of it.
Nik,
