OK, I have a heat wrench that will let me straighten out the bottom of the rod. I just wish I could get the casting off the rockshaft. I'm going to try drilling the spirol pin out. Too bad it's all been recently painted. Lesson: fix broken stuff before you paint.
I had the problem with the other end breaking. I took mine to a machine shop in town and for about $20 had a new button and rod made. The button was a little "big" but i ground it down on a bench grinder. I had him make the button a little longer also.
Just my $0.02 Good luck. John |
Good luck John FYI a QL and 108 handles should be same and interchangable. But dont quote me and anyone can tell me im wrong. |
can you just get a new rod and button
You need to get the old button off to remove the rod. I was able to remove one with plenty of pb blaster and a needle nose pliers...
Up to 534 and counting... I give up updating my profile! |
The button broke in the middle, so I don't think I can push it out from above. It's too far in to grab with needle nose pliers. I think I'm going to try to bend the "J" at the bottom straight (with the oxy/acet torch.) If I can push it up enough to grab the end of the broken button I might be able to unscrew it. Then I'll need to remove the rod, re-bend it, and reinstall it. At least that's the plan. Unless anyone has any other ideas.
Here's an idea. What if I used my stick welder set to 240Amps, hooked one lead to the "J" and the other to the old button, wrapped in tape. Then put it in the hole and held it against the pin. Would it weld itself together?
Might be easier to break the "L" off the bottom of the rod and pull it out the top. You can get a screwdriver in around the "L" part at the bottom and pry it down then get ahold of it with vice grips to break it off. Then unscrew the button, weld the "L" part back on then slide it back up through the handle and screw a new button on. Just a thought.
Sorry, didn't see Ray's post... I thought the bottom was a separate piece that was welded to the rest of the rod, but yeah, what he said.
No, not good enough to hold anything anyway..... But, It would get that rod REALLY, REALLY HOT and quick too.... At 240Amps, it may just melt in a second. It's not much bigger than a welding rod.... and no flux on it to keep it cool. Plus, it would weld the rod the guide where the spring bottoms out.
