Old 06-09-2013, 09:56 PM
sawdustdad's Avatar
Default Replacing manual lift release button
My manual lift button broke at the point it narrows down so the float button can engage it. So it's down inside the lift arm. Looking for suggestions on how to proceed.
Old 06-09-2013, 10:22 PM
That SUCKS! At this point.... no ideas. I'll have to sit on a bucket and think about that for a bit. Anyone else?
Old 06-09-2013, 10:28 PM
I've got the entire apparatus still mounted on a 1200 frame that you're welcome to if that helps you at all.
Old 06-09-2013, 10:52 PM
You might as well take this offer. It is probably your best option. I had that happen to me before and although it isn't easy to replace, it is the easiest option that I found. I drove my cub so that the front tires were on my trailer and the rear ones were on the ground. Then I removed the ramps and CHOCKED THE REAR TIRES...so the cub doesn't move. In fact, chain the cub to the trailer for added safety (now I think of that...). This will give you added clearance for removing that manual lift rod and replacing the other. Another option would be to take it to a garage that has a pit to it.
Old 06-09-2013, 10:54 PM
I just noticed your cub is without an engine and hood/grill. I'd just lift it up and chain the front end to a tree or the rafters of my garage and swap out the manual lift arm.
Old 06-09-2013, 11:05 PM
I'm not exactly sure what model he is working on. Are the manual lift handles all the same?
Old 06-09-2013, 11:09 PM
No they are not. Good eye, I overlooked that aspect--sorry. He is working on a WF (wide frame) model 108 or 109. Is yours a WF also? If not, then our sponsors at the top have that part.
Old 06-09-2013, 11:16 PM
1200 is a QL WF...
It's his for shipping cost if he wants it... If he feels like being a champ, he can toss a case of domestic my way.
Old 06-10-2013, 07:30 AM
sawdustdad's Avatar
I'll take you up on that, domestic and all. Sent you a PM. Yeah, I'm working on a 108.
Isn't that lift button screwed to the top of the internal rod?
I tried to remove the roll pin through the lift arm casting (holding it to the rockshaft) but without much luck. If I get a replacement arm, I can cut it off if I can't drill the pin out. I do have a couple solid carbide drill bits I haven't tried yet...
Old 06-10-2013, 08:59 AM
Looked up the lift for a 108 on the Cub parts site. The button is screwed to the rod. Can you get the rod out of the arm from the bottom?
