do you have a coil from another tractor?
Up to 534 and counting... I give up updating my profile! |
No I don't. I'll see if I can get one from a friend on Monday. Or just replace it on Monday.
Gene 149 w/Front Blade
You should test it first beforehand with an ohmmeter, can't just start throwing new parts in it without a few simple test.
Here is the Check Out Procedure for the Kohler Ignition Coil. http://www.onlycubcadets.net/forum/showthread.php?t=11 |
Hello there! I did not have much luck at all going with the 321 p.carb. adjustments given in that k manual. I went up and down with that manual and my engine never preformed right. I set mine to a k 301 and I have a smooth running engine.
I'll go out on a limb and say its fuel related because the machine fires right up. A very basic test for spark, compression, and fuel it all that's required.
I would like to say, many years ago I had an engine start and idle all day, but would not throttle up.
Fiddled around for a whole day, on a hunch I removed the condenser, and tested it, sure as heck it tested bad, so I substituted one I had laying around, and it ran as expected so I purchased the specified one and all was well. Just my $.02 |
X4 on the condenser. Shows itself a lot more with a single cylinder engine
Thanks guys for the suggestions. I'll get the coil checked this afternoon. I'll have to wait 'til Monday to get a condenser. I used the settings from the Kohler booklet as a starting point and was able to tune it in before so I think that process is okay. Got to get to work, thanks again.
This summer had a condensor wire broke 2/3 in two would do this, pop backfire would run right. I always keep a spare coil, points and condensor on hand. Just because the condensor has a few hrs on it doesn't mean it's not bad. I've had a new coil out if the box be no good.
Good luck! Let us know what happened.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
