Old 04-01-2021, 10:29 AM
If it is a normal fitting, both ends of the fitting will fit in the pump!
I have used a fitting meant to be a tube union fitting,
inotherwords to connect two flared tubes together.
I'll try to get some pix up soon.
The only thing I can think of is maybe his early fitting is a tapered pipe thread
where it screws into the pump.
but like you, I think a parker man should of picked up on that.
Old 04-01-2021, 11:07 AM
ironman's Avatar
ironman ironman is offline
Old part no. was IH-7273009. Search for that Cub part comes up with IH-9410204.
https://www.ebay.com/itm/NEW-INTERNA...QAAOSwcwhVKotJ
Old 04-01-2021, 11:41 AM
That is exactly what I have in my pump, and both ends have the same thread.
It is a standard hyd/parker fitting that needs an "O" ring to seal the fitting at the pump.
the price is not that bad either with no shipping added!
Old 04-01-2021, 11:47 AM
Billy-O's Avatar
Billy-O Billy-O is online now
I'm am curious to why the original poster needs a new fitting? I'm sure he'll have to replace the ferrule or o-ring which should be easy enough. But does he not have the fitting from the original suction tube?
Plow blade
#2 Cart
QA36 snowthower
Old 04-01-2021, 12:06 PM
Ambush Ambush is offline
Male ORB (ORBM) to Male JIC (JICM)
Same thread pitch on both ends. Dealer modified/repaired if that doesn't fit?
Old 04-01-2021, 05:47 PM
Think he mentioned he had a different suction tube than we are used to seeing.
Maybe it is an early design we are not familiar with??
I'm sure he will post back.
The pump should have the ORB ( O ring barb) to Jic flair.
But a lot of things in this world I don't know or have not seen.
Old 04-02-2021, 08:39 AM
Bump.
How are you progressing on your fitting procurement?
Do you need more pix than Iron man posted?
just curious.
Luck!
Old 04-03-2021, 02:24 PM
FlatBar's Avatar
FlatBar FlatBar is offline
Thanks for all the input/help on figuring out my connector issue. Thanks to Ironman's part numbers I was able to find one at an old IH dealership.
The reason I needed that part is because I am converting from the original style 147 tubing to the later 149 style. It has less connectors and in my thinking would be less likely to leak. However it is pretty clear to me now that my very bad hydro leak is not from the suction tube or the hydro/rearend gasket but is higher up near the top. Thinking that it was the hydro/rearend leaking, I bought a supposedly new gasket but it did not have the cloth backing like the one in Gerry (Kendall) Ide's write up. So I bought another one from a different source and it doesn't have the cloth backing either. Did they switch back to a composite cork gasket without the cloth? Is it advisable to use that type or should I make one from gasket material?
I want to leak test it before I put the rear end back in the frame. Has anyone ever spun the hydro with a drill? I tried and the drill would turn it, but I wasn't sure what to do with the hydro controls.
I also have my sons pinewood derby race next Saturday and that will slow the cubs progress this week.
Let me know your thoughts about the gasket and leak testing, thanks.
Old 04-03-2021, 05:39 PM
mortten mortten is offline
If it leaking nearer the top check the hydro relief valves.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 04-03-2021, 06:15 PM
TheSaturnV's Avatar
2nd for relief valves.
Since they are tucked up underneath the main chassis they have a good place to hide. Pull the fender pan, then push it about 6ft or so and then wait. You'll probably see one leaking out the top.
