Old 10-09-2022, 07:24 PM
beancent beancent is offline
You were correct with the extra 4 was not part of the serial number. Going by a photo I took this time it is 2050594U665171
Old 10-10-2022, 06:16 AM
OK, you have an early IH built 782. I'll dig out the diagram and send it to you.
Old 10-10-2022, 09:30 AM
Ok, Thankyou
Old 10-10-2022, 09:59 AM
Check your email.
Old 10-11-2022, 05:23 PM
Rolland, did you receive my email that said i would like the relay version for my electrical mod. Not sure if my email reached you.
Old 10-22-2022, 05:39 AM
Thank you Rolland for sending those early 782 with M18 wiring drawings. I was able to start up my new to me magnum 18 and after replacing the fuel pump using the one off my old KT17 series II, it started up and ran good. The only thing left is to find how to adjust the air fuel and idle screws on the carburator. Does any one know how to adjust for a starting point on these screws and which one is air/fuel and which is the idle adjusting screw. I'm seeing one that looks like you can grab with your thumb and forefinger and the other needing a flat blade screw driver. I also noticing a screech noise coming from the starter, as I activate the starter when turning the ignition key. My old KT 17 has a newer starter that I think can be used as a replacement.
Old 10-22-2022, 07:49 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
Yes the KT17 starter is the same as the M18 starter. The engine will need to be raised up to wiggle it out.
Top screw is main (high speed) fuel feed, side screw is for idle. Baseline on the main screw is 2 turns out after LIGHTLY seating the mixture screw, and 1.25 turns for the idle. Then fine tune for best performance and smooth operation AFTER the engine is up to operating temperature. Main screw is adjusted first and then idle. The main screw does affect the idle mixture.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 10-22-2022, 07:56 AM
1711Cub's Avatar
Lightbulb
Some adjusting insight in this video
https://www.youtube.com/watch?v=eBjWpHyL4L4
Old 10-22-2022, 07:58 AM
On my carb I see three screws. One small with spring pointing straight up on top of throtle body, and one pointing out at a slight angle with larger screw knurled head and the third smaller sloted head pointing out sideways.
Old 10-22-2022, 09:05 AM
Farmall450's Avatar
Does one impact the throttle idle position?
The 2 on the left side are for main & idle fuel/air adjustment.
