Old 09-02-2015, 07:47 AM
sbauerz28's Avatar
I just bought a new one. I got it a few month ago, but have yet to get the ambition to pull the wheel to install it. Maybe someday before the snow flies.
Old 09-02-2015, 09:42 AM
FrankF3's Avatar
FrankF3 FrankF3 is offline
That turned out real nice Frank. My 882 dash is still holding up well so I think you'll be good for another 30 years.
thanks, I'm hoping for the same amount of life to it. Now, my 1572 actually has some holes worn through it. I want to get this one done before the snow flies. The dash I had in the pictures is a spare one I have. I don't know if it is easier to patch it in place or swap it out. I'm thinking of all the things that need to be removed to take the dash off.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 09-03-2015, 06:47 AM
Workinprogress Workinprogress is offline
Here is the repair. In my case the lower end was completely worn through. I was able to work the putty into the crack and flatten it on the back side. While I never completed the repair (final sanding and painting) it has not broken. You can see the slight wear of the putty on the top edge. That is 2+ years of wear. This was a quick repair ( 5 minutes) to keep the dash together. So the putty is definitely an option to do a quick a repair without removing the dash.
Old 09-03-2015, 06:29 PM
I now run a piece of Armaflex pipe insulation between the hood and dash when I'm plowing to keep the metal from wearing the plastic.
Old 09-04-2015, 01:30 PM
SGragg SGragg is offline
Inactive Member
FrankF3: I know about good intentions and "meaning to get back to that". It appears your repair is excellent. Time will tell, but it should last a good, long time.
Thanks for sharing your pics and technique.
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 09-04-2015, 07:06 PM
FrankF3's Avatar
Thank you Stanton. You are right, time will tell. I know that the JB weld is harder than the original plastic, but if I was able to get it to be totally black, then when it starts to wear again, then you wouldn't be faced with the gray underlying material. I wanted to document what I did, so if someone on here wanted to repair one also they would have a means to do do, including the part number of the paint I used.
Old 09-11-2015, 08:12 PM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
Not a dash repair but a preventative. Today I took a piece of latex tubing slid it inside the seal at the firewall. I think this will keep most of the weight off of the dash.
Old 09-11-2015, 08:20 PM
FrankF3's Avatar
So you put the seal inside the seal? do you have a picture so I can see how you did it?
Old 09-12-2015, 12:03 AM
gdheck's Avatar
gdheck gdheck is offline
Frank,
I think the tubing was to make the original seal stiffer, so it holds the weight of the hood instead of the dash holding it.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 09-13-2015, 12:31 AM
FrankF3's Avatar
Originally Posted by gdheck View Post
Frank,
Thanks, I'll have to give this a try.
