#31
Try it with the gas cap off,, If it were mine, and still did it,, I would set up a nurse tank (it would look like an IV bottle) and feed the carb directly, no tank, or pump, involved. Only if it then runs, can you start looking for a problem. I bought a two year old tractor, the FIRST thing I did was empty the fuel tank, flush it, and fill with clean fuel. Now, I admit, that was a diesel, but, I did not like the way the fuel "looked" The tractor ran MUCH better after cleaning the tank, and changing the fuel,,, |
#32
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
#33
I really don't know exactly. Twice I had to push it back to my shed and maybe an hour later it would start up. Being that it only happened the last 3 times I don't have an accurate time frame.
CC Model: 127 w/42" deckCC/MTD Model: 2155 w/42" deck |
#34
I'll give the gas cap a try first. I would think if the pump was bad it shouldn't act like that, work then not work but I'm far from being an expert on these kind of matters.
#35
Ran into this exact symptom of run a while then sit for an hour to start etc that
you are describing. After these good fellas gave me the same advice to make sure all was spic and span. I pulled and cleaned the tank replaced all fuel line ( cheap fix) and cleaned all thing gas excluding carb and fuel pump. That was 4 years ago and it hasn't missed a beat. My opinion as a student here at OCC is clean clean clean. Then worry about the other stuff. Ken |
#36
#37
Well I tried it with the gas cap off. I put a new fuel line from the tank to the pump and new filter. I put a new fuel pump on (from fleabay) and it did the same thing so I put the original back on. It still only runs for about 20 min and thats it. When it quits the fuel filter hardly has any gas in it. So the only thing that I can think of next is the electric pump unless somebody has any other remedies.
#38
I used a low 1-2 psi Facet #40177 in my 782 with a KT-17 Series II and wouldn't have it any other way!
Loader 102 with Snow Thrower 147 with wood chipper 782 rebuilt With 50" belly mower 1200 with Haban Sickle Bar 1450 restored with Roto Tiller 1512 with Snow Plow |
