#41
Wow Nick, that was a fast turn around and comeback from a bad experience! You are the Man! Great Job!
Keep dragg'n em in. They're like orphans...they all need a place to call home. |
#42
Thank you Bill
#43
Well there is another way. In kohler manuals it says if it's really bad you can weld a lot on the journal and then grind it until it's back to the factory dimensions. Be hard but I don't see why a profesional welding shop couldn't do it. Just a thought......
#44
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
#45
When you weld a crank, the welding shop doesn't do it. You take it to a crank shop and they have a submerged arc welder that they use. OR... a welder than I can't remember the name of right now... but it basically "blows" hot metal onto the journal. It sounds odd, but it is a method of welding that is less evasive with less heat and warp-age. But Kelly is correct.... even my crank shop won't weld up the Kohler cranks. The hollow journal makes it prone to cracking.... ok... it WILL break. Now that shop only has a submerged arc welder, not the other machine. I asked him once if he would do it with the other style... he still said no. This is the same shop that works with Vogel MFG, so..... he know's what he's doing. |
#47
I will politely disagree with you on that statement. I have had a crank ground farther down than .020 and had the rod machined for an insert. That engine has 10 yrs on it now and still going strong.
#48
Closing this thread down.
#49
Guys
I went back into this thread at the request of the OP and deleted the argumentative comments. So if any of you wonder who it was that deleted your posts it was me. If you wish to discuss the issue feel free to PM me. This thread is now closed again.
