Old 01-26-2016, 10:55 PM
Originally Posted by adamo View Post
Except when I run jumper cables from a battery to the s/g it turns over. It is with the A terminal lead disconnected from tractor.
I know. You said that already.
Did you tap on it with a hammer lightly while trying to start it with the key like I asked?
Old 01-26-2016, 10:57 PM
adamo adamo is offline
I hate to admit when my wife is right...
yes. just a click.
Old 01-26-2016, 10:59 PM
yes. just a click.
You did hold the key in the start position while tapping on it right? You didn't let go of the key?
Old 01-26-2016, 11:00 PM
budscub's Avatar
budscub budscub is offline
Default From a battery
Have you tried this using the battery that is installed on the tractor. I see you are using a different battery sitting on the running board.
Try it using the battery that is installed on the tractor.
Gary
1974 1650 50A "budscub" Was my fathers
1969 125 42"
1978 1450 44A dual hydraulics
1984 782 50C dual hydraulics, waiting for vanguard
Z-force Cub cadet Zero turn
Sears '66 Suburban 10 Sears '66 Suburban 12
2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow
74 "Green 100 "John"
Old 01-26-2016, 11:01 PM
Yes. held the key- used a rubber mallet- whacked it like 10 times. nothing.
Old 01-26-2016, 11:05 PM
Do what budscub said real quick. Use the actual battery that is in the 129 and the jumper cables. Does it still crank?
Old 01-26-2016, 11:12 PM
Ok. just did- same result.
Old 01-26-2016, 11:20 PM
I appreciate the help guys. Thank you for trying. I'll try again in a week or so when I'm not so frustrated. I appreciate the help though. For now I guess it's still haunted.
Old 01-26-2016, 11:22 PM
Don't you dare give up, we're not done yet!!!
It's not f---- haunted, you haven't finished testing yet. If you want to give up now while we are in the middle, why not just load it up and take it to a mechanic? Reach down and grab the pair you have, go back to the garage and finish the tests, we're almost to the end!
Tags
129, electrical probs, no crank
