#71
![]() Biggest issue at the moment is time, as in not enough of it.
#72
Thank you! I appreciate it.
#73
OK, time to finish this off.
Since I had the radiator and block drained of coolant I ordered up a couple of new radiator hoses. I wanted to make sure that I did my best to avoid having an air lock in the block so I pulled the thermostat before refilling the system. I made a new gasket, tested the thermostat for proper operation and refilled the system. |
#74
I picked up a new D4LT - VHD battery from Interstate. Made up new 1/0 fine strand, pre tinned battery cables and installed the rebuilt Lucas starter.
#75
Installed a set of gauges.
#76
Ooooo, that's a biiiiig battery, how does a 70 y.o. get that in there?
Otherwise you are doing a great job covering all the bases.
#77
Priming the fuel system was effortless. The ol’ Boy fired right up and the straight pipe and flapper sounded so nice. Oil pressure ran right up to 60 and settled down to 50 at idle when warm and volts was a steady 12. I set the low idle at 800 rpm as a starting point and headed out for a run around.
When I got back the temp was up to 150 F. and I noticed a small leak from the radiator cap and a little coolant dripping from the overflow tube so I put that on my list for the next parts run. When I removed the cap I noticed that the top of the filler neck was a little bent so I straightened that out and installed the new cap. I turned the idle down to 700 and I'm gonna watch that temp and prolly try a higher temp thermostat. |
#78
I’ve mowed three or four times with it over the past week and it really is a pleasure to operate. The size is perfect for the Woods mower that I picked up last year.
What makes a Ford 4000 Special Utility unique is that it has the engine, transmission and rear end from a 4000 and the steering, front end and (now I know) gas tank from a Ford 3000. This combination makes for a nimble tractor with gobs of power! Thanks for following along! ![]()
#79
![]() I’ve gotta hand it to mister two ton he has demonstrated over the years to probably be the most thorough guy on here. Great job!
#80
Nice work!
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]()
| Tags |
| cav injector pump, ford 4000 su |
