Old 10-03-2011, 09:28 PM
staylor1650's Avatar
staylor1650 staylor1650 is offline
Default needing some information
i just overhauled the 10hp on my 100 first it has a new starter generator on it and it is getting hot you cant hold your hand on it, secondly its making a clanging noise i don't think its a knock but cant be for sure i cant place where it is, i torqued the rod to 22ft lbs
75 Cub Cadet 1650
64 Cub 100
not cub but its yellow 62 allis chalmers b-10
Old 10-03-2011, 09:39 PM
LarryW's Avatar
LarryW LarryW is offline
Is the starter generator overcharging? Maybe the voltage reg went bad?
Cub Cadet 147 2050041u340160
Cub cadet 129 main mower
Cub Cadet 1811
Old 10-03-2011, 09:49 PM
They do get hot after running a hour or so but check the voltage at the battery with a meter,no more than 14.2 volts or it will overcharge. That may be your PTO making that noise.Does it have the anti rattle clips?
Up to 534 and counting...
Old 10-03-2011, 10:41 PM
i haven't put the front pto on yet and no there are no anti rattle clips on but it sounds like the noise is coming from the motor i just cant place it
75 Cub Cadet 1650
64 Cub 100
Old 10-03-2011, 10:48 PM
Is it coming from your clutch,did you replace it?
Old 10-03-2011, 10:51 PM
Just throwing out a question, you did make sure to orient the rod correctly with the oil hole facing the cam side of the crank?
Old 11-03-2011, 10:01 PM
found my knocking noise i took the pan off of it a rotated the crank by hand
the piston wrist pin was moving inside the rod so i pulled the piston and my rod was bad it was a factory 10hp kohler brand part i never thought to check it because i never even looked at the rod i just wrapped it up with the crank and sent it off the get a bearing made for it. now i have to send this other rod off should have paid more attention to my parts i guess
75 Cub Cadet 1650
64 Cub 100
Old 11-03-2011, 10:41 PM
the insulator on the pos post isn't melted is it ? -- possible the rear bearing is dry and worn/loose or a front bearing I would pull it and check it out or have it checked before you cause costly damage
128
