Old 12-12-2011, 09:58 PM
Default How I Tighten Tire Chains!
I have heard the deflate-inflate method. I do not want to be deflating-inflating when the snow is flying and the chains shift and become looser.
The rubber car binders are too big and dry rot in a couple years.
I like steel!
That spring is extended about 1/2".
The chain is a piece left over after I cut the chains to fit the 23x10.50's.
As the chains shift during use, the slack will be taken up.
Did I miss anything??
I will slap these on the QL1000 when the snow flies!!
Old 12-13-2011, 06:45 AM
Leadslingingdaddy's Avatar
I used these on my Super worked great....
Old 12-13-2011, 07:16 AM
nikster's Avatar
nikster nikster is offline
Gonna have to look into a set?
I like'em better than the bungie cords I use.
Nik,
Old 12-13-2011, 07:18 AM
jbollis's Avatar
jbollis jbollis is offline
I deflated my tires when I put the chains on about 5 years ago. I have not had a problem with them moving at all. I even deflated and filled them with fluid this summer. They went right back to were they should be.
If you get them on correctly and tight, they will not move.
Sold everything but one.
Old 12-13-2011, 11:33 AM
I did the same two years ago, and haven't touched them.
Old 12-13-2011, 08:10 PM
Merk Merk is offline
I never use bungie cords, springs or any extra device to hold my chains on.....as jbollis said
by jbollis
agree
Old 12-13-2011, 08:56 PM
Same here 3 years and no problems with the 2 link spacing on 3 tractors...
Up to 530 and counting...
