Old 02-08-2012, 06:23 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
Default Wheel Weights
I found some weights at the mower junk yard , and the guy wanted 100.00 for 2 40lb wheel weights. ( not cub but would fit it)
3 years ago I made 2 25lb weights ( red ones in the pic) that seemed to be enough for pushing snow around here. but I dont think its enough for pulling a plow. and sence I still have the plate, I cut out some more. I now can put 95 lbs inside each wheel.
Ill start cutting out the suitcase weights tomorrow. need to make a bracket too.
Doug
Original , 100 , 125 , 582
Old 02-08-2012, 07:15 PM
Nice torch work 4SPEED
Old 02-08-2012, 08:52 PM
TheIHMan's Avatar
TheIHMan TheIHMan is offline
Nice weights!
Old 02-08-2012, 09:30 PM
Originally Posted by TheIHMan View Post
Nice weights!
I agree too!
Old 02-08-2012, 09:57 PM
4SPEED's Avatar
thanks. they still need some grinding.
I welded 3 plates together to get 30.4 lbs and 4 plates welded came to 40.3 lbs. and the red top plate is 24.7 lbs
I use the wifes bathroom scale to check them. I dont know if it right or not , the wife told me it lies and must be broken.
Doug
Old 02-08-2012, 10:35 PM
I hear ya 4SPEED
Old 02-08-2012, 11:19 PM
I hear ya 4SPEED
Old 02-08-2012, 11:27 PM
Nice job on the weights!
Old 02-09-2012, 12:45 PM
That'll work
Old 02-09-2012, 02:09 PM
4SPEED's Avatar
test fit. I can get all 3 weights bolted together off the 582. but can only get the 2 on the wheel. I can almost get the 3rd weight on but one hole is off almost 1/2 a hole.
Im going to drill the 3 holes a little bigger and weld shut and redrill the 4th hole.
other then that, I think they will work out fine. and the fit inside the wheel is good.
Doug
