Old 03-24-2012, 06:16 PM
drcjv's Avatar
drcjv drcjv is offline
Default 1572 pto problems
I was cutting grass today I hit a bump and the pto turned off and would not come back on. I discovered the fuse had blown every time I turn on the pto the fuse blows. I unhooked the pto at the plug and turned on the switch and the fuse did not blow. Any ideas is the pto field shot? can I just change the field or do I have to get the entire pto? Can they be rebuilt? Any ideas where to get a used one.
Thanks
Charles________________________
1572 3pnt, rear PTO, 50" deck
1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow
1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow
2072 3pnt 50" deck, Brinly Plow
2072 50" deck
Cub Cadet Tank 50 Zero Turn
Cub Cadet 33" Commercial Walk Behind
1953 Ih Cub with just about every implement
New Holland TC33D with Loader and Backhoe
Old 03-24-2012, 07:33 PM
The field coil, according to Cub Cadet, is NLA. You might try the sponsors listed above.
Old 03-24-2012, 08:26 PM
You might want to see if the lead in wire is grounded, or if the coil insulation is come off allowing the coil to rub on the rotating disc.
Sometimes the coil can be saved by using Hobby epoxy or even JB weld.
If Not, try out sponsors @ the top of the page.
