Old 04-22-2012, 08:43 PM
cubby102's Avatar
cubby102 cubby102 is offline
Default i know its not a cub but it is a kohler
My dad has a old John deere 112 I bought him last winter to plow with and I recently figured out its not charging . If I pull a battery cable off while running it just flat dies any ideas on what the problem could be? What should I try testing to trace the problem down? Any ideas would be great thanks.
Old 04-22-2012, 09:12 PM
If it is a starter gen setup (thinking it is) but can't remember,
ground the "F" terminal on the S/G, if it charges, then look to the regulator/wiring/grounds for problems
there is a procedure here might have do a search.( I can''t remember the link)
Old 04-22-2012, 10:03 PM
cubby102's Avatar
i wish it was a S/G setup but its got the regular start with a 15A ? alternator...thats why im stumped never really messed with a kohler setup like this, i was just lookin for some quick tips before i actualy dig into it a little more got it running good tonight now to work out the gremlins. i thought it was weird that the guy had a brand new deep cycle battery in it
Old 04-22-2012, 10:05 PM
You might try weekendfreedommacines.com
Old 04-22-2012, 10:44 PM
cubby102's Avatar
thanks ill give it a look
Old 04-23-2012, 08:56 AM
Ok newer system,
Check to see if you have voltage comming out of the voltage regulator/rectifier
( center terminal About 14V.) with engine running fast.
if so it is in associated wiring, if not, prolly regulator/rectifier
Old 04-23-2012, 10:18 AM
cubby102's Avatar
Thanks ol George ill check that out later tonight I nst got off work and I'm beat. Third shift makes k hard to get stuff done around here
Old 04-23-2012, 10:32 AM
BTDT 40+ years,
down load the manual from kohler or one on here so you might do a search or just google it,
it will walk you through test procedure prolly something simple or maybe rect/reg.
is it a early round fender? like them, got one for my son, he still uses it although it has the tec. HH100 engine.
luck!
Old 04-23-2012, 07:49 PM
cubby102's Avatar
Nay unfortunatly its not a round fender but it does have a electric lift with locking blade which is why I bought it for him he didn't want my 102 cuz he's a deere guy and he just had surgery on his right arm last year so the lift makes it easier on him.
Old 04-23-2012, 08:14 PM
Nuttin wrong with Deere, got a 210 for a spare mower a 70D and 730D
along with my Farmall 400 & 806 on the play farm.
It looks like Christmas with red & green and a persian orange just for tint. Ha,LOL!
