Hello all! Was wondering what octane of gas do you use in your tractor? 91 or 87? Thanks,..Brian
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
Just my 2 cents but I use Shell 93 only because it's the only thing in this area without ethanol. I have better things to do than rebuild carbs.
I use 87 and pay the 10 cents extra to get no ethanol!!
![]() I would use the 93 if it were the only thing available with no ethanol.
Amen to that. In my town our shell station is the only station that sells a grade of gas without ethanol. It usually only comes out to be a dollar more per 5 gallon can so like sam said. I also have better things to do then rebuild green nasty carbs
Nick. ![]() Cub cadets 100, 125, 86, 108, 109, 128, 129, 129, 149, 149, 169, 1450, 1650 and a handfull of parts tractors. #40 box blade, ih back blade, rear ih rock rake, #2 cart, windbreaker soft cabs, windbreaker hard cab, cozy cab, kwikway loader , wards corn planter, brinly plows, culitvator, rear blade, disc and the usual decks, snowblowers and 2 tillers |
87 octane with 10% ethanol and don't have any problems with it.
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
First thing you need to do is check a Kohler service manual. There is one in the tech section of the site.
Try using the search function on this site. This subject has been beaten to death. Hard to say how many topics or comments that have been made on fuel with ethanol subject. You have some who don't have problems and some who claim they do have problems. |
87 w/sea foam
Gary '49 Farmall Cub, '62 "Original, '70 73 w/402-D Haban sickle, '71 127 w/38" cast end deck, '73 149, '76 Sof76, '07 LT1045 w/bagger, '09 GT2544 w/bunch of mods. 5 Exmarks, Kubota B2920, blah, blah, blah... |
I occasionally dump some E-85 in to clean things up a bit and also put in about a quart of diesel to lube things up a bit in my 782. Works great but most of the time I use 87 with 10% ethanol.
1200, 1450, Red 782 |
91 with Marvels Mystery Oil. Pretty sure it's ethanol free. Unless they changed the law about posting that info on the pumps.
87 no ethanol.
