Old 08-31-2012, 01:26 PM
rlatz rlatz is offline
Default Are these ok to lift with?
I was going to just pull the tins and power wash but there is so much gunk under the motor that I'm going to pull it out first. Are these tabs heavy enough to lift with? They seem centered enough on the engine. While it's out I think I will check the valves and put new head gaskets in. Looks like it may need crank seals as well.
Rory
1985 1711
Attachments: 44C deck, 42 front blade, H48 snowthrower
Old 08-31-2012, 02:58 PM
red56turbo's Avatar
I just pulled the engine out of my 782 to replace a leaky crankshaft seal as well. I used those exact lift points without any problems. The cherry picker worked great! Sure saved my back.
Josh
Diesel Cub Cadets...........
Old 08-31-2012, 04:02 PM
Thanks Josh! That will be the plan then. I hear ya a few years ago or 20 I'd of wrassled it out of there by hand .
Rory
1985 1711
