Old 03-24-2013, 01:18 AM
Default 1864 oil seal and carb upgrade
I'm headed to pick up a new cat 0 toy for the 1864 and spring is coming so thought I would get the 1864 ready for work. Looks like this has been leaking oil for a while. I guess with Uncle Gene having the oil shop it was cheaper to put oil in then replace the seals. I've got lots of degreasing to do.
Attachment 34590 Attachment 34591
Attachment 34592 Attachment 34593
Old 03-24-2013, 01:20 AM
I've got the carb upgrade to turn this into a 24 beast. I new stator to fix my non charging problem and a new regulator.
Old 03-24-2013, 06:36 AM
Looks like you will be, sing it "Goin to the car wash baby"
Old 03-24-2013, 07:56 AM
Definitely time for a degreasing Duke!
Coming along though slacker!
Old 03-24-2013, 08:14 AM
Duke
While you have the engine out don't forget to clean and re pack the CV joint for the tilt steering, you may need to also remove the battery tray to get at it. I'd pop the flywheel off before you wash it since you’re going to be inside that area anyway for the stator and rear seal. Glad to see it doesn't have the SAM ignition module.
Old 03-24-2013, 10:13 AM
Good pics, Duke! The engine in my 1872 was also just degreased!
Old 03-24-2013, 10:45 AM
Thanks guys! Yep heading to the car wash for sure.
Old 03-24-2013, 10:49 AM
After a few of those the guy at the local car wash asked me not to come back LMAO
Old 03-24-2013, 10:51 AM
I might be joining that club today.
Old 03-24-2013, 11:00 AM
Drive up to Virginia to wash that engine. The snow coming down will cover all the grease at the car wash while you make your getaway!!
