Has anyone tried this? Can it be done and how much trouble would it be?
If you are any good with metal, should be no problem.
Does anyone have a picture of the frame for a snowplow on a super?
The frame on the supers is longer, but not wider. I don't see any reason why you couldn't just lengthen the braces that run to the back. The blades for the supers were a completely different design. Looking at those wouldn't help you much. Unless you want to make a whole new sub-assembly.
cut the slotted ears off the back end of the blade frame and add a piece to lengthen the frame [around 4 inches if I remember correctly] and weld the ears back on wouldn't hurt to plate the frame where it is spliced to reinforce it and add a cross brace between the frame ears...
I set the plow under the 2072 looks like it will be an easy modification...
