Old 09-20-2013, 01:50 PM
JRJP56 JRJP56 is offline
Default Deck Lift Spool Valve Question
Since I haven't had a hydraulic lift on my previous Cub the deck lift feels a little sticky and I'm wondering if the valve should be self centering, is there a cure or cleaning I can do to resolve this issue? Any help would be appreciated. Thanks!
Old 09-20-2013, 01:54 PM
YES, the valve is self centering. I spray some PB Blaster on the Spool Valve control shaft and makes my SV work real good.
Old 04-13-2014, 11:48 AM
CLE CUB CLE CUB is offline
I have the same issue with my 1450 dual hydo to the point where I have broken 2 spring pins on the solid inner handle. Is there any way to clean the valves out or otherwise correct the sticking?
-- CLE CUB --
1946 Farmall A
19?? Speedex 840
1971 Cub 108 42" Mower
1975 Cub 1450 Power Angle Plow
1979 Cub 1650 44" Mower & Snowblower
1991 Jeep Wrangler Islander 34" Super Swampers
Old 04-13-2014, 11:50 AM
Take it off, disassemble it, clean it, install new o-rings, sand the rust off the spool, put it together and back in.
Old 04-13-2014, 12:11 PM
Will def start there. Thanks.....I am not too familiar with hydraulics and was unsure what to expect when I took the spool apart. Excellent project for a beautiful day.
-- CLE CUB --
1946 Farmall A
19?? Speedex 840
