Old 05-12-2014, 11:17 AM
BVanEps BVanEps is offline
Default Grabbed this over the weekend
Paid $350.
PO said it hasn't run in several years though he was able to start it with ether but it wouldn't stay running. After draining the tank, I can believe it wouldn't start. Gas looked like some mixed A&W Cream Soda with Orange Kool-Aid. Only time I've seen darker gas was when I drain the tank on a pickup that had been sitting for 6-7 years or more.
The fireball when I threw about 5-6 ounces in the fire was only about a third of the size it should have been.
I figured shouldn't be to tough to get it going. Clean the tank out, clean the carb, and replace the lines and fuel filter.
Hoping I can get it running so I have something to clear the rougher areas while I try and fix the hydro leak on the other 1811, otherwise it'll be a donor for the other one.
Old 05-12-2014, 11:38 AM
Nice score on the 1811!
Old 05-12-2014, 01:05 PM
SGragg SGragg is offline
Inactive Member
Nice! Actually looks to be in good shape.
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 05-12-2014, 01:11 PM
Congrats on the nice looking 1811!
Old 05-14-2014, 07:26 AM
Congrats on a nice looking 1811. That one looks too nice to be an organ donor.....save it.
Old 06-13-2014, 10:59 AM
Well, finally got this 1811 running after getting my other one back together and hooked up to the tiller. As I thought, just needed to replace the fuel shut off valve and bushing, some fuel line and filter and put in fresh gas. Guess it won't be a donor.
Now the question-
I have it idling at about 1200 - 1250 rpm and at 1/4 - 1/3 throttle the rpms are stable at about 2400-2600. But when I go over that the rpms climb into the 5000-6000 range. Am i looking at a bad governor or an issue in the carb? Any advice would be appreciated.
Thanks
Barry
Old 06-13-2014, 06:04 PM
The M18's & 20's are kinda known for governor gears breaking. I have one that does the same thing that has been in the barn for a few years now. Can you adjust it or see it move at all?
Old 06-13-2014, 07:08 PM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
That's how it starts, donor tractor. (wink, wink) Nice score.
Old 06-13-2014, 07:49 PM
CubDieselFan's Avatar
Nice 1811.
