Old 06-15-2014, 03:11 PM
Trx2.5rcnitro Trx2.5rcnitro is offline
Default 125 Hydro drive problems
Hello I have a 125 with a weird problem. If I keep the engine at low
Rpm's it will drive forward and reverse, but at soon as I rev it very much
over idle it loses all drive. Throttle back down try to go again and after a few
seconds it will go again. Just changed to fluid and cleaned all the gunk
out. Any ideas what could be wrong. Or what to check/adjust.
Old 06-15-2014, 03:36 PM
Did you change the Hydro Filter..???
Old 06-15-2014, 03:51 PM
No the filter I got was to long and wouldn't fit, so I will have to return it tomorrow and get and different one
Old 06-15-2014, 05:00 PM
Well, start with the filter. If it doesn't fix it, let us know.
Old 06-15-2014, 09:55 PM
larry03061976's Avatar
larry03061976 larry03061976 is offline
Yup. I just went through the exact same issues with mine. You need to change the filter and all should be well! Good luck!
Old 06-17-2014, 04:53 PM
Got the filter changed and it works. Now to work the bugs out of the carb.
Thanks for the advice I would have never guessed that a filter would caused it to
do that.
Old 06-17-2014, 09:09 PM
do that.
Good to hear!
Old 06-17-2014, 10:17 PM
do that.
Great news!
Old 06-17-2014, 10:25 PM
If you don't mind the mess it would be fun to cut the old filter open to see just what is inside...
Old 06-18-2014, 10:14 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Must be a whole lotta junk.
And not the bypass when plugged type filter either
