Old 06-21-2014, 04:40 PM
larry03061976's Avatar
larry03061976 larry03061976 is offline
Question 125 neutral adjustment?
Ok, before everyone yells "DOWNLOAD THE MANUAL!" I am doing posts from a phone that for some reason wont allow me to. My question is do I adjust the nuetral position by adjusting the linkage that runs from the handle to the trunion assy? Thanks in advance.
Old 06-21-2014, 05:33 PM
No....Wait until you get to a PC & download the manual as seen in our Technical Library Section. IIRC, around pages 2-70.
Old 06-21-2014, 06:02 PM
Roland you were faster. I was going to post the page number. It's 2-55.
Old 06-21-2014, 10:16 PM
ryanschm2 ryanschm2 is offline
Here's a Youtube link to someone making the adjustment.
http://youtu.be/phz_VqTZFRI
Ryan
Cub Cadet 2072 "Super"
Cub Cadet 782
Old 06-23-2014, 07:53 AM
This looks like it's way easier on a tractor with a tunnel cover that can come off. I've been pouring over the service manual (because eventually I've got to do mine, probably sooner than later) and I suppose I won't know until I get in there and try it, but how difficult is it to do on a NF? Can the cam bracket bolts be accessed when the tractor is coupled?
Old 06-23-2014, 10:14 AM
charlie105's Avatar
charlie105 charlie105 is offline
Default NF hydro adjustment ?
Have the same question. Looks akward, and dangerous to do without decoupling. Forever hopeful !!
Old 06-23-2014, 11:18 AM
Guys..... you can't adjust neutral with it out of the tractor. It has to be coupled. Service manual tells you how to do it.
Old 06-23-2014, 01:12 PM
I know it has to be adjusted while together. No other way to tell if the driveshaft isn't connected, etc etc. I've been reading the service manual. What I don't understand is it can't be adjusted the same way on a NF like the video shows because the tunnel cover is in the way. http://www.youtube.com/watch?v=1FKS15y_WWQ Does one access the cam bolts from underside the machine to tighten them?
Old 06-23-2014, 01:23 PM
I don't know how else you would get to them...... Lay on your back! Or, do what zippy does, actually I do too, and stand it on end!
Old 06-23-2014, 01:56 PM
cubs-n-bxrs's Avatar
Just a quick heads up on the cam plate bolts. All the narrow frames I have adjusted I have found the heads are 12pt. Having a fine tooth rachet helps big time as well.
