Old 09-01-2014, 05:15 PM
nutzboutoldies's Avatar
nutzboutoldies nutzboutoldies is offline
Default QA42A scraper blade
Hi all, I'm beginning to get the 1450 ready for the upcoming winter. Last spring I noticed the scraper blade was bent/bowed. I was afraid housing was bent also. After removing the blade it appears the housing isn't to bad however the blade is bent pretty bad. Amy of you replaced the blade? It looks like it's not available. I can probably straighten the blade but I'm afraid the strength will be lost and it wouldn't last long. How have you guys dealt with this?
Steve
1450
QA42A Thrower
44A Mower
Old 09-01-2014, 05:39 PM
timbo2's Avatar
timbo2 timbo2 is offline
A Machine shop could probably copy it close enough. Take it while it's still in one piece
That's what I did for the scraper on my snow blade in the past.
- Tim
Old 09-01-2014, 06:41 PM
Mike in SD's Avatar
Mike in SD Mike in SD is offline
Xtreme Motorworks has them,
http://xtrememotorworks.com/Parts%20.../CC-26-002.htm
HTH
Mike
Old 09-01-2014, 09:01 PM
Sometimes, if they aren't too bad then they can be reversed and the other side used. You can also purchase another one, as was mentioned ....they are also on Ebay, etc..
