Old 04-26-2015, 03:46 PM
Default Simplicity wiring help
Hey guys,
I'm trying to hook up all the wires the PO disconnected.
I can't seem to figure it out, I have an F post, an L post and a BAT post, and a post underneath the voltage regulator, I did run a wire from the BAT post on the voltage regulator to the pos on the battery, any ideas?
Old 04-26-2015, 04:30 PM
It wires up the same as a NF Cub Cadet. Use one of those diagrams.
Old 04-26-2015, 04:31 PM
mmzullo mmzullo is offline
http://www.simpletractors.com/servic...al_systems.htm Look here.
Old 04-26-2015, 04:53 PM
Thanks, I tried following the wiring on a cub but I got it cranking even though some wires aren't hooked up and it backfires and the crank shaft kicks back the opposite direction.
Old 04-26-2015, 05:05 PM
That's an engine problem, not a wiring one.
Old 04-26-2015, 07:04 PM
O.C.C or is it O.S T.?
Up to 534 and counting...
Old 04-26-2015, 07:53 PM
He posted in the General Talk area so he's is just fine here. It's a Kohler so I don't have a problem with the question he is asking and I doubt that any of the other Mods have a problem.
Old 04-26-2015, 08:06 PM
Sam,
It is a briggs,non cub,Can I post about my variator troubles on my JD 110 ,it has a kohler in it?
Old 04-26-2015, 08:10 PM
Sam,
OK with me. That's why we have a general talk area. I've posted my JD dump truck in this area.
Old 04-26-2015, 08:14 PM
Ok guys settle down.
