Old 04-27-2015, 09:14 AM
TigerCub's Avatar
TigerCub TigerCub is offline
Default 122 Electrical question
I got the new wiring harness hooked up, new battery installed, double check all my connections with the wiring diagram. I'm not electrically inclined by the way.... Just for curiosity I wanted to see if it turned over and nothing happened, neighbor came over and said maybe the neutral switch is bad so he disconnected and put a jumper wire in place, still nothing.
Anyone have any ideas what could be wrong?
Mine:
122 with 38" Deck, 123 with 48" Deck, 1650 with 44" Deck, #1 Tiller, QA42 Snowthrower
My Dad's:
Red 382 Hydro, Red 482 Gear
Old 04-27-2015, 09:25 AM
Fireman72737 Fireman72737 is offline
Was the 122 working running before? Why did you replace the wiring?
Always Looking for More!
Old 04-27-2015, 09:33 AM
TigerCub's Avatar
It didn't have any wiring, only things it had were voltage regulator, coil, starter, solenoid, and neutral switch. I had to buy an ignition switch and a harness for it.
Mine:
My Dad's:
Old 04-27-2015, 09:40 AM
Are you sure, it is wired correctly....???
And, the Neutral Safety Switch is temporarily jumpered out.....???
Old 04-27-2015, 09:43 AM
TigerCub's Avatar
I followed Mike's labels and double checked the diagram he sent. We pulled the plug on the neutral switch and jumped a wire from one side of the plug to the other.
Mine:
My Dad's:
122 has a clutch/brake switch but no "neutral" switch.
Old 04-27-2015, 09:49 AM
TigerCub's Avatar
Maybe that's what that is on the underside of the frame, the parts diagram said neutral switch. The one thing I didn't check is if the battery was charged, but I assumed since it was new it would be.
Mine:
My Dad's:
Old 04-27-2015, 09:58 AM
Is the tractor wired per the #5 diagram contained here.... ?? Wiring Diagram
Old 04-27-2015, 10:03 AM
TigerCub's Avatar
Yes, here is a few pictures if that helps.
Mine:
My Dad's:
Old 04-27-2015, 10:52 AM
I smell fresh paint. Check all the grounds on the starter solenoid, s/g, and the grounds on the dash tower.
Up to 534 and counting...
