Old 09-01-2015, 06:15 PM
Donny Curtis's Avatar
Donny Curtis Donny Curtis is offline
Default Are 108 and 1000 frame the same
Are these frame the same , was wondering if 1000 side shields fit a 108
Donny
Old 09-01-2015, 06:42 PM
Originally Posted by Donny Curtis View Post
Are these frame the , was wondering if 1000 side shields fit a 108
No idea what you are asking? Is this some sort of auto spell from a phone? "Are these frame the"? Try again.
Old 09-01-2015, 07:58 PM
I think he fixed it.
Quiet Line side shields won't fit a 1X8/9.
You may be able to change the grill shell & muffler and get them to work, and air cleaner.
Old 09-01-2015, 08:02 PM
The frames should be the same.
Old 09-01-2015, 08:05 PM
cubby102's Avatar
cubby102 cubby102 is offline
They may take some massaging but I don't think it'd be to hard to make work. As far as I know the only real change in the frame itself is how the engine mounts.
Old 09-01-2015, 09:06 PM
the side panels wont fit with the starter/generator on the 108.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-01-2015, 09:25 PM
cub123's Avatar
cub123 cub123 is offline
As was said I think the frames are same. Putting on side panels would also require the proper engine shrouds, firewall, Etc to cool correctly. Probably not worth the trouble.
Old 09-01-2015, 09:54 PM
Yup, I forgot about the S/G, and yes, it probably wouldn't cool well.
Old 09-01-2015, 10:57 PM
Default 108
Father in Law, was going to put a 14hp with ring gear starter on it, was wanting side shields on it.
Donny
Old 09-02-2015, 07:59 AM
mickb72 mickb72 is offline
Default cub
Hi Donny, i do know the clutch release levers are different. Got one from Z Kerber and it was a little long. Had to move the clutch hanger up. Difference between a frame mount motor (108) and frame rail mount.(QL) Mike
