Old 04-19-2016, 02:03 PM
Jeff122's Avatar
Jeff122 Jeff122 is offline
Default 122 Hydraulic lift pump leaking
I searched the threads and can't locate the answers. The hydraulic lift pump on my 122 is leaking from the front just a little bit. Is it difficult to change the seals? Where's the best place to get a seal kit? And what type of oil is used in the pump? THanks all.
Old 04-19-2016, 02:31 PM
I have never had the seals leak on any of mine yet, but you might check your fittings and make sure that everything is snug before buying a seal kit. I use Hytran (same as rear transmission) in all of my hydraulic lifts.
Old 04-19-2016, 02:56 PM
Jeff122's Avatar
Very good point. Never thought of that. Thank you.
Old 04-19-2016, 03:47 PM
Jeff122's Avatar
"Hytran". Is that a type of oil made by various manufacturers? What name brands should I be looking for?
Old 04-19-2016, 03:59 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Hytran is what International Harvester put into the rearend/transmission on the hydrostatic version (123) of your tractor when they built it.
Can still be had where they sell Cub Cadets and/or parts.
There are also other brands that claim to be an approved substitute per their labeling.
Old 04-19-2016, 04:01 PM
DoubleO7's Avatar
this thread will answer many other questions about the hydraulic unit and rebuilding it, seals, etc.
http://www.onlycubcadets.net/forum/s...c+unit+rebuild
Old 04-19-2016, 04:11 PM
Jeff122's Avatar
Thanks. Tractor Supply might be an option. There's only one Cub dealer around here. I saw a product on line made by Cub Cadet, but it was called drive system fluid. Same thing?
Old 04-19-2016, 05:08 PM
PM member Yosemite Sam. He has seal kit for it
