Old 05-18-2016, 08:06 PM
Dillardcn Dillardcn is offline
Default LTX1045 will not run
Need some help here, I have a 2 year old LTX1045 with the wonderful kohler courage. This past Saturday I was cutting the grass next door to me (foreclosed house) and hit a root stuck up. It killed the engine but fired right back up, but would not idle up, so I pulled it up to my building and cut it off. Since then I have tried to start numerous times, it will turn over but not run. I'm not a mechanic but have tinkered on many things. Here's what I know- plug is firing, carb. Solenoid is opening and closing, fuel is getting to the plug, keyway is still in place and has compression (finger test). After I checked fire on plug I gave it a shot of starting fluid and got a back fire and that was it. I'm about to pull my hair out, can someone please tell me what I'm missing.
Old 05-18-2016, 09:00 PM
I'm guessing it's still under warranty I'd take it back to whoever you bought it from and let them deal with it, that's why you paid the big $$$ for a Cub Cadet.
