Old 10-24-2016, 12:16 PM
Default Locking Adapter In Place
Has anyone ever came up with a way to lock your Brinly adapter in place? I notice when I pull my lawn sweeper, the adapter wants to move up. I was wanting to see, if there was a way to keep the adapter from being able to move. Looking forward to any suggestions, guys!
Old 10-24-2016, 12:31 PM
Isn't your adapter raised and lowered with a winch? That's not really an issue with the proper setup.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-24-2016, 12:35 PM
It sure is, Tim. I wish there was a way to lock it with the winch.
Old 10-24-2016, 12:41 PM
Can't you just take the adapter off and use the regular hitch?
Old 10-24-2016, 12:46 PM
You could make a bar that would wedge between the adapter and winch mount, then you could raise the winch to secure it in place.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-24-2016, 01:10 PM
Jonathan, it doesn't have the regular hitch. I would have already done that, if it did.
Old 10-24-2016, 01:11 PM
Sounds like a good idea, Tim.
Old 10-24-2016, 01:53 PM
CSXengr's Avatar
CSXengr CSXengr is offline
Allen, you probably need another tractor just for lawn sweeper duty!
CSXengr
_______________________________
124 w hydro lift, 124 creeper gear, 125,126,128, 129,147 electric lift, 149 w/tiller, 1200, 1450 dual 1650 w/tiller control hydro, #2 Cart, Haban sickle mower, Gannon, 17 cubic inch cart.
Old 10-24-2016, 02:05 PM
I'm sure there are a thousand pictures of the back of your tractor floating around but I can't find them...
Every time I "search" for "Allens rear end", something less than desireable comes up.
Post up a picture, maybe you can make up some kind of stiff arm for it.
Old 10-24-2016, 03:34 PM
Allen this is an easy one. Just cut a piece of wood that will fit between the frame and the hitch. See yellow box, put it in place and then just put enough pressure on the lift to hold it in place.
Or hang some weight on the tongue of the sweeper.
