Old 12-05-2016, 09:44 PM
Bamafan Bamafan is offline
Inactive Member
Default My Method for getting stubborn pulleys off spindles
Yesterday I ask for some information on removing the pulleys from the outside spindles off a 44c mower deck. I got 3 responses from J-mach, Deltacub, and darkminion17. All were good suggestions and I truly thank you for your input. But they were to naught.
So last night I went to bed with this on my mind and when I awoke this morning I had an idea. Straight to my shop even before coffee I went to work and I had them off in about an hour without any damage.
Thought I would share this on a new thread for anyone having trouble removing pulleys it worked really well for me.
First of all remove the top nut an air Impact wrench is suggested.
Then to the drill press and drill 2 - 1/4" holes one on each side of the pulley nut and tap the holes with a 1/4" tap
Then bolt your puller to the pulley and it will pop off, but it is best to use some good penetrating oil I used PB blaster and let them soak over night.
I don't know if this is the right forum to post this in but this method worked for me and I wanted to share it. Maybe it will help someone who is trying to rebuild spindles and save some$$$.
[B]Larry[/B]
Old 12-05-2016, 09:47 PM
Shotgun Clay Shotgun Clay is offline
Slick idea
Clay
149, 125, 100 w/ rear pto, fenders, and hydraulic lift. 5 snow plows, 1snow thrower, #2 ih cart
Old 12-05-2016, 09:51 PM
Did you remove the grease zerk that was on top of the spindle? I have done that trick for the pto basket pulley.
Up to 534 and counting...
Old 12-05-2016, 09:53 PM
john hall's Avatar
Not a bad idea, but I'd have had to have coffee FIRST.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 12-05-2016, 09:58 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Nice trick Larry! I cant believe that dollar store puller withstood that kind of abuse!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 12-05-2016, 10:01 PM
It doesn't look happy
Old 12-05-2016, 10:04 PM
Inactive Member
Yeah I removed the grease zerk, the hole is perfect to hold the puller in line.
[B]Larry[/B]
Old 12-05-2016, 10:08 PM
Inactive Member
Belive it or not it's homemade by my dad. Many years ago. I sure do miss him.
[B]Larry[/B]
