Old 11-20-2017, 10:01 PM
jd8181 jd8181 is offline
Default Fluid change
I have heard this both ways and wondering what you guys do. Do you change your fluids before you put your mower away for the winter or do you change them in the spring? Also why do you do it the way you do?
Old 11-20-2017, 10:22 PM
john hall's Avatar
If equipment is just going to sit or only cranked periodically, we leave the fluids in it until spring, then change them. That way if there is any condensation that forms over winter, it gets drained away. We do make exceptions (obviously) for stuff that has to have the fluid drained to be worked on.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 11-20-2017, 10:33 PM
If I'm going to be using the tractor in the winter then i change the oil to the proper viscosity and then change it back in the spring, if its just going to sit then i wait until spring to change it.
Pap's 100
Restored 108
1211 Dual Stick
1050
