Old 04-05-2018, 02:58 PM
ibohunter ibohunter is offline
Default GT2186 starter problems?
I have a GT2186 and it started to have a problem when you push the brake pedal in it won't start and it sometimes take maybe 6-8 times till it starts. I was thinking it could be the switch on the parking brake, any help would be helpful, thanks in advance
Old 04-05-2018, 09:16 PM
CubDieselFan's Avatar
I have several mowers with engines just like yours. You could have battery problems or connection problems. You could need to do the starter relay upgrade. Here is a link.
http://www.onlycubcadets.net/forum/s...t=1864+starter
Old 04-06-2018, 08:22 AM
It seems that the switch is not engaging correctly when you push the brake pedal in
Old 04-06-2018, 10:23 AM
2 things could be happening comes to mind.
One, could be the brake safety switch is defective and needs replaced.
Two, could be the ignition switch is failing and needs replaced.
I suggest you check continuity of the brake safety switch first with a meter or test light.
If ok then check the Ign switch for power to the solenoid activation wire.
Report back with your results.
Old 04-19-2018, 05:31 PM
Default gt2186 starter problems
the brake lever was not always hitting the switch, we had to take it apart and make a bracket and fasten it on the brake lever and now it starts like new
