I've already got my 1650 engine partially disassembled and now I need to roll the tractor into the garage to work on it. But stupid me didn't test the hydro release lever before I rendered it immobile. How can I get the thing to roll if the release lever in front of the seat doesn't do anything?
- Bill Cub Cadet GT 2000 gone but not forgotten: Cub Cadet 1000 Cub Cadet 1650 |
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
Floor jack? Kids skate board? You could pull the relief valves out of the top of the hydro, but it will pump oil out all over. If you have a set of automatic relief valves you can install them for the time being to allow you to roll the tractor.
149, 2072, Original, 1772, 1782, #1 cart, Parker 48" sweeper, |
Take off the tunnel cover and see if the release lever is broken. Before i fixed my 1450 that had a similar issue i just put a jack under the rear end jack it up and drag it around (jack has wheels). Assuming it isn't too far from your garage this might be an option.
edit: doc beat me to it.
Tanner |
Auto relief valves-should be able to move.
Manual relief valves-Take drive shaft tunnel off and push and hold button on top of relief valve(s) down. You should be able to move your 1650. You may need a helper to move it. I moved my 149 by holding the buttons down on the top of the relief valves.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
Floor jacks works as stated... if needed
Remove tunnel cover. Put a magnet on each valve, it will hold it down.
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
It is 50 yards out back so no jack stands or skateboards will work.
What does the release lever forward of the seat activate? What you say "see if it is broken" do you mean see if the lever is no longer attached or ???
There should be a metal flap attatched to the lever. They are often broken off.
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]()
He is talking about the flat metal thing in this picture. It pushes down the buttons on the top of the release valves. You can't see it unless you take the tunnel cover off.
