Old 01-14-2019, 07:36 PM
Dstein16's Avatar
Dstein16 Dstein16 is offline
Question Changing Hydro Fluid
Newbie question of the day.
What do I need to do to change the hydro fluid on my super? I believe it has a 1572/1772 rear end. The fenders and fuel tank are from a cyclops. I can't find a drain plug anywhere. I assume the rear cover will have to come off to drain the fluid? 3 point and rear PTO make it a little more challenging...
P.S. - ignore the tin can next to the super
-Derek
Cub Models: Original, 100 (x3), 1282, 1572, XT1 LT46
Old 01-14-2019, 08:23 PM
It has a drain plug in the front bottom next to the suction tube below the filter.
Old 01-15-2019, 09:42 AM
PaulS's Avatar
PaulS PaulS is offline
If it were me I first would be sure to get a new proper filter and hydro fluid. If after draining the tranny any milky colored fluid would prompt me to remove the rear cover and really clean out the cavity. I use a thin plastic tube down the fill tube which makes filling a bit easier. It mostly cures the burp back of fluid making a mess of tractor and person.
Old 01-15-2019, 10:27 AM
Dstein16's Avatar
Thank you Sam and Paul. I will call the local Cub dealer to see if they stock my filter and a couple gallons of HyTran. The manual states 8 qts. capacity. Does this sound right?
-Derek
Old 01-15-2019, 04:16 PM
7-8 qts of fluid this is a list of approved filters, most can be found at your local auto parts store.
Cub Cadet 923-3014
NAPA 1410
Wix 51410
Fleetgard HF6096
Baldwin BT8486
Tags
change, filter, fluid, hydro, super
