Old 12-03-2019, 02:45 PM
ac_top_cat ac_top_cat is offline
Default 1962 Original restore
I'm in the process of restoring my 62 Original. I have it all torn apart down to the frame and I am wondering how you guys clean the frame. Pressure washer? Degreaser and a lot of rags? Its sitting in my garage and I have no floor drain if I use pressure washer or hose. Any other ideas?
Old 12-03-2019, 06:47 PM
I usually scrape off what comes off easily than use rags and a drain pan of some sort for the really greasy stuff. Use a spray bottle and some mineral spirits. Spray it on and scrub with a parts washer brush, tooth brush or whatever works.
Then it's off to the sandblaster.l
Old 12-03-2019, 07:20 PM
Merk Merk is offline
I'm the same boat as you are. When it gets cold will take it to a local car wash. I use Simple Green or Castrol Purple cleaner to clean the tractor. .
Project Uncle Dick
Cub Cadet 70
Old 12-06-2019, 11:08 PM
What color is muffler supposed to be? I see both black and silver.
Old 12-07-2019, 07:37 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Take it to the coin op car wash.
Spray on oven cleaner is good for a presoak there.
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
