Old 02-09-2020, 02:17 PM
PennDude PennDude is offline
Default Favorite mods or additions to your Cub?
My wife and I inherited a 149 that needed an engine rebuild. It’ll be done in a few weeks and I’m more than a little excited to have a tractor. We’ve been push mowing and carting everything around with a wheelbarrow ever since we bought our home 4 years ago. So, now that we’ll have a functioning tractor, I want to know what your favorite additions or modifications have been. I have a dump cart, mower deck, and plow. The tractor has a sleeve hitch.
Old 02-09-2020, 02:29 PM
That would very depending on the size of your lawn, terrain, and tasks you want to do.
Old 02-09-2020, 02:43 PM
I’m asking for YOUR favorite additions and mods. Of course it all depends. We all have different situations, preferences, tastes, etc.
Old 02-09-2020, 02:51 PM
I took a pull behind Spring Tooth De-thatcher and and made a custom mount so I could lift it with my sleeve hitch. I have an array of tow attachments, and front end snow removal implements.
Old 02-09-2020, 03:27 PM
RLause's Avatar
RLause RLause is offline
Power steering and Cat-0 on my 782.
Richard
Old 02-09-2020, 04:17 PM
john hall's Avatar
I'm not much into modifications on my stuff, but I have put the ball bearing upgrade on the steering on a few. I have ag tires on my "all terrain" mower, makes it 10 times more useable for where I go with it to mow. If you are going to run at night, put in LED lights, I've done it on farm equipment and the difference is beyond amazing.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 02-09-2020, 05:34 PM
LED headlamps are on my shortlists, along with front wheel bearings and a Ross Steering upgrade.
Old 02-10-2020, 12:01 AM
SS5150's Avatar
SS5150 SS5150 is offline
Backlit amp and oil psi gauges on my 782, fluid filled tires on 782 and 1050, new tires on my 1050.
RUN IN THE RED
782 w/50c deck (red); 782 dual stick, 44c deck (y/w);
1050 w/38c deck; 1864 w/54" GT deck;
1872 project
Cub Cadet Pro Z 560 L
42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper
1200, 1863, 1864 parts machines
Old 02-10-2020, 11:56 AM
Jumper Jumper is offline
PennDude,
I agree with everything above, but I also have to add:
1) loader and weight box, throw away your wheelbarrow ��
2) Stone rake and rear blade, great for apple and spring yard clean up.
3) Snow cab
4) Sweepster front broom, I don't know how big your yard is, but works great.
5) Front mounted chipper. (Reduce yard waste size for compost)
6) Box blade works pretty well for driveways and leveling loose dirt.
These will be a good start ! (after you start you can't stop)
Old 02-10-2020, 09:45 PM
The PECO Leaf Vac system has proven to be a very handy attachment for me. It cleans up the yard nicely from leaves and grass clippings on a regular basis. It also serves as a carry all for logs, stone, mulch, bags of salt, etc. putting the weight on the rear axle.
