Old 11-21-2020, 09:00 PM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
Default 3225 Hydro
Is there some trick to prime the hydro pump on these things?
Old 11-21-2020, 09:58 PM
CubDieselFan's Avatar
What happened to it that it needs priming? Did you service it?
Old 11-22-2020, 05:53 PM
had to replace rear end do to broken case. now can't get it to prime
Old 11-23-2020, 07:56 AM
ejl6658 ejl6658 is offline
I have had to replace seals in a couple aluminum differentials and replace a broken case on a cast iron differential and have not had to prime the pump. An incorrect filter or a broken gerotor in the pump can cause the pump not to build pressure. Are you using a cub cadet transmission filter?
