Old 02-07-2022, 10:19 PM
CubbyRI CubbyRI is offline
Default 18HP twin cylinder into a narrow frame?
Im sure this has been tried if not done, but I am starting to install a loader onto my 123 and my buddy has an 1810 he started it for me and wow how smooth that twin is...
how hard would it be to fit one of those engines into a 123?
Model 100 Dec 2020 - Running condition, has snow plow!
Model 123 Nov 2020 Hydro needs much work, or resto, building front end loader for this one
Model 100 Feb 2019 apart for total frame-off / sandblast etc resto
Model 70 Sep 2020 needs total resto and an engine, or for parts
Model 70/100 Mar 2021 buried in rust, frozen engine, got free for parts.
two spare hydro rears
"in for a penny, in for a pound!"
Old 02-08-2022, 06:27 AM
With a Cutting Torch, metal, a Welder, fabrication, and some tools, I see no problem.
Old 02-08-2022, 07:20 AM
Anything is do-able, but sometimes common sense is a better choice.
Old 02-08-2022, 09:09 AM
ironman's Avatar
ironman ironman is offline
You left out skill.
Old 02-08-2022, 12:33 PM
haha. I got ALL that...
smoother and much more HP... I also like the Onan P series engines too...
so... has this been done?
Old 02-08-2022, 12:57 PM
Common sense says why reinvent the wheel?
Time one hacks the sides of the frame down to clear the cylinders and weakens/ ruins it then scabs on reinforcing plates and what all else needs to be done if one expects to have a hood/side panels,
it is so much easier to just start with a spread frame, designed to bolt in an opposed twin.
And hanging a loader on a Garden tractor is borderline abuse, but many people do it, but are careful understanding a GT was not designed for loader or a back hoe so caution is exercised during usage.
Hell, you can set a small block Chebbie in front, and it would be a conversation piece, but the usability is diminished hugely.
We all dream, and that is how things get built but some thought/experience must go into the project.
Just my .02 cents, no offence meant to anyone.
Old 02-08-2022, 01:29 PM
why would I have to cut into the frame, cant the opposed horizontal twin sit on top of the frame rails? then make an adapter to the hydro drive shaft...
Old 02-08-2022, 02:22 PM
As an educated guess, I would venture to say the drive line geometry would be off.
Old 02-08-2022, 03:09 PM
Not worried about driveline geometry. I can make a little drive shaft with a little universal joint at each had no problem.
The other option is to put a pulley on the engine and another one on the drive shaft with a pillow block bearing for support.
I'd rather do that than alter the frame.
I was so impressed with the smoothness of that engine on the 1810... I read up on those engines and they're good but I did read that the Onan P series engines might be even a little bit better especially since they have more torque down low.
Old 02-08-2022, 03:18 PM
Here, watch this... If you have any questions ask him he is very helpful.
https://www.youtube.com/watch?v=GhcgbeXIj94
Up to 534 and counting...
