Old 05-05-2023, 09:34 PM
Jchow2156 Jchow2156 is offline
Default 1862 Ignition/wiring issue
I have been working on an 1862, the ignition switch was bad so I ordered one by the number on the old switch. It has a plug with 5 wires and a single post to the side for the green ground wire.
hooked up when you activate the key it keeps blowing the fuse. Disconnect the green wire and it doesnt blow the fuse.
Motor turns over but cant get it to start. I know it runs cause we had been cranking it with jumper cables.
Can someone please help me and guide me with this issue. Im thinking it has something to do with the safety switches.
Thanks
Old 05-06-2023, 08:12 AM
Did you get a Cub Cadet #925-3163 Ignition Switch ??
Old 05-06-2023, 09:18 AM
Yes, that's the one I got
Old 05-06-2023, 09:24 AM
So, you have a new 925-3163 and you are blowing the fuse.
(A) Do you have a VOM or DVM meter ??
(B) Do you know how to check for "resistance" (Ohms) ??
Old 05-06-2023, 02:12 PM
Yes I have a multimeter, spent an hour yesterday checking wires, connectors, grounds , resistance etc. . Also when the brake is unlocked from the locked position it'll blow a fuse
Old 05-06-2023, 02:39 PM
Sounds like something is shorting to ground when you release the brake.
Old 05-06-2023, 02:56 PM
How about when the ground is connected to the switch it pops the fuse when key is turn on. I'm assuming it's all a ground related issue?
Old 05-06-2023, 04:43 PM
This is the wiring diagram for the 1862
Old 05-07-2023, 12:04 PM
Ok. I've got that problem fixed. It cranks with key and not blowing fuses.
Now the pto will not stay engaged. It activates but doesn't stay engaged. Any ideas on this issue. Thanks for all yalls help
Old 05-07-2023, 01:31 PM
What was the problem ???
Now the PTO will not stay engaged. It activates but doesn't stay engaged
One of three things.
* Bad Seat Switch
* Bad Reverse Switch
* Bad Reverse Relay
This is assuming the wiring is intact, and in good condition.
