Always wondered. Why a transmission but not an engine oil filter? Got me to thinking about it today while changing the oil. I've been changing the trans filter every year of late - probably wouldn't need to since the tractor runs way less than 50 hours a year.
I do not know the engine you are referring to but I assume it is one with no oil pump. No pump means no filter.
My push mower has no filter , splash feed works pretty well so long as you do not mow at an acute angles and change the oil regularly using a good quality oil
B&S motor Oz
My wife says I do not listen , at least I think thats what she said |
My Cub Cadet 129 - Kohler 301 engine
A simple splash system, thus no pump no filter.
If you can find a K330 or K331, they have an oil pump, but alas no filter.
It is probably overkill but on my K301s I change the oil a couple times
at least through the summer. Probably amounts to every 10-15 hours. I figure it is a pretty cheap filter system. Just drain and fill. Ken |
Same with some KT17 and maybe even M18 applications.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
Thanks for the replies! Have a good Sunday everyone.
my 1225 from 1992 has no filter either.
