Old 09-07-2010, 04:55 PM
moon2013 moon2013 is offline
Default cub cadet 128
how do you install the v belt on a cub cadet 128? are there any tricks to it? how long should the belt be?
Old 09-07-2010, 06:12 PM
Are we to assume, the V Belt is for the mower deck....??
Old 09-07-2010, 06:22 PM
the v belt that connects the mower deck to the pto clutch
Old 09-07-2010, 06:45 PM
Is this what you are looking for...???
Old 09-07-2010, 08:53 PM
If you need advice, I usually hook it up to the PTO first, then guide it through the pulleys on the front of the mule drive and then I roll it onto the main center pulley of the deck in a CCW fashion using a flathead screwdriver while cranking the pulley around by hand---sometimes I have to reach under the deck and use the blades to get enough leverage to roll the center pulley. FOR SAFETY SAKE, I always disconnect the spark plug whenever I do this!!
Old 09-07-2010, 09:00 PM
Moon 2013 click on this link and scroll down for the mower deck manuals .
http://www.ccmanuals.info/pdf/
Old 09-17-2010, 12:02 AM
goony goony is offline
Yeah, I do the PTO first, then get it guided thru the two idler pulleys, then the main pulley on the mower deck using the method described.
If you loosen the belt tension nut to the end of the travel on its rod you can usually just roll the belt onto the mower deck pulley with your fingers as you hold it in the pulley and pull the belt along in the direction that would wind the belt onto the pulley.
Goony
Tags
128, cadet, cub, v belt
