Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Kawaski Engines
Old 04-14-2026, 08:19 PM
MBman MBman is offline
Default FR691V Kawasaki Engine with low idle hunt
Have done all I know to do , cleaned out cooling fins, fresh gas new filters , plugs ect. Runs and mows great , just hunts idle at low RPM. I have found nothing wrong with the governor springs, cleaned carb with carb cleaner and run thru cleaner , no change. Even tried to adjust the "hidden " screw on top of the carb without change. What am I missing ? Or any other ideas
TIA
Ron
Old 04-15-2026, 12:14 PM
CubDieselFan's Avatar
Did you remove the carb and take it completely apart to clean it?
Old 04-15-2026, 07:18 PM
I have not , but I was worried Id ruin at least a running mower.
it looks simple to remove
I thought that carb cleaner and run thru cleaner would work. In your experience is carb removal my next step. What would one clean that in , and will I need a carb kit - if there is such an item?
thanks for any insight
Old 04-16-2026, 04:51 AM
Here's a vid of a guy cleaning one. I didn't watch the complete vid but maybe this will help.
https://www.youtube.com/watch?v=jl1_eUAVm18
