Old 09-15-2010, 03:39 AM
cdlong's Avatar
cdlong cdlong is offline
Default Sleeve hitch question
I have purchased a sleeve hitch with floating arms. While looking at different sleeve hitches, I see some have a bent disc with a hole in the center. What is this disc for? Mine doesn't have this disc, is it needed?
Thanks
Old 09-15-2010, 06:29 AM
It is for sway control.....
Old 09-15-2010, 07:48 AM
You'll definitely need it.
Old 09-15-2010, 08:52 AM
I have done a lot of plowing and never used one of those. I don't think it's the end of the world if you don't have one.
Old 09-15-2010, 09:27 AM
Admittedly I have never plowed, however I do use a box blade, cultivators and a disk. I have several sleeve hitch adapters but no draft plates, never had any problems without one.
Old 09-15-2010, 12:40 PM
I'll have to plow without it next time, to see if there is any difference.
Old 09-15-2010, 05:12 PM
Merk Merk is offline
The stablizer plate is needed if your attachment has a single hole hitch.
Old 09-16-2010, 04:47 AM
cdlong's Avatar
Ok, thanks guys!
