Old 10-07-2010, 05:12 PM
Merk Merk is offline
Default To Rebuild or Not to Rebuild?
New member Dan post this in a different topic:
by RebuildK321
I'm brand new to this site and not sure how to navigate as of yet. However, my issue involves a cub 149 14hp Kohler. It was my second summer using my "new to me" cub and I committed the unpardonable sin in not checking my oil, as I thought my motor was not using. I had borrowed some gas to finish up a yard and cut my own grass late in the evening a day or two later. I saw some smoke but immediately thought of the borrowed gas and thought there was oil in the gas. Well...the rest is history and I'm seeking the right solution from all you veteran cubbers as I try to consider whether to rebuild or find a good running motor somewhere else. Money IS an issue for me at this time. What are my options? Where is the right motor? Or who can I call to rebuild without breaking the bank? The original purchase price including a PECO vac system was $710.00, which I thought was a steal, unless you have to buy it twice... The tractor does have some sentimental value so I intend to keep the existing body and vac system. You guys are seasoned pros, so I will put alot of stock in what you say.
The time for "being sick about it" and "regret" are over. It's time to go forward and I would appreciate anyone's time and expertise.
Many Thanks,
Dan
Here is a link to orginal post:
http://www.onlycubcadets.net/forum/s...ead.php?t=6461
Dan,
It is hard to say what needs done to your Cub with the infomation you gave. We need some more details so we can be able to help you out.
Does the motor still turn over?
Is there any extra holes on the side of the motor?
Is the motor together or do you have it apart?
Depending on how soon you need to have your Cub running can be a factor too. I tell everyone to expect 2 to 3 weeks to have the motor back together when I rebuild one. Two main reasons are waiting on parts and machine shop to get the machine work done. Expect to pay $125 to $175 for labor to have a K321 motor rebuilt. Parts and machine shop work can run $200 to $350. Depending on how much work you do you can save some money. You can buy a cheapie rebuild kit on e-pay.....the parts are substandard in my book. I wouldn't use or recomend them.
My Son I usually will rebuild 3-4 Kohlers a year.
One of our sponsors should be able to supply you a motor. You need to contact them.
Old 10-07-2010, 07:48 PM
jeffscub's Avatar
jeffscub jeffscub is offline
what is a PECO vac system? jeff
'72 108 w/ 38" HIGH speed deck, '77 1200QL w/ homemade grader blade, '79 1450 44" grass tamer, '70 sears super 12 w/ 3pt , 19?? 100 w/ extra toys, 69' economy powerking 14 horse w/ FEL, 65' economy powerking w/ toys, 1982 allis chalmers 716
Jeff
Old 10-07-2010, 09:01 PM
NealC NealC is offline
Jeff,
PECO is a company in North Carolina that makes vacuums for mowers. They have been around for quite awhile. You could order units built for IHCCs back in the day. Although you cannot buy a new one specifically made to fit older cubs, they still make units for new mowers.
http://www.lawnvac.com/resources.html
Old 10-07-2010, 09:07 PM
jeffscub's Avatar
ahhhhh ok, i've seen them advertise something like that on tv here. like the cyclone rake or something. thanks for clearing that up for me!!! jeff
Jeff
