Old 10-20-2010, 12:57 PM
JOHN SCHUTTE's Avatar
JOHN SCHUTTE JOHN SCHUTTE is offline
Default Dash repair
I have a 1250 that I will be painting soon. The dash i belive is fiberglass which i have no experience with. The lip where the hood rest on it is broken in the corners. I have a friend who is good with fiberglass that is going to repair it. My question is about the painting process of this dash. Do i need to rough it up? Special primers? Any info will be greatly appreciated.
Old 10-20-2010, 01:21 PM
cubs-n-bxrs's Avatar
John you would prep the fiberglass dash just like prepping a piece of steel. Any automotive grade paint and supplies will work just fine.
Old 10-20-2010, 03:35 PM
Thanks for the info!
Old 02-27-2011, 10:12 AM
young enthusiest's Avatar
How about sandblasting? Is that allowable or no? I have a few I need to do
Old 02-27-2011, 10:37 AM
jeff k.'s Avatar
jeff k. jeff k. is offline
I wouldn't sand blast fiberglass, just rough it up some.
cub cadets : orignal w/ mower,orignal w/ push blade, orignal w/BB-36 snow thrower,72w/creeper,100, spirit of 76,76,55, 95 Electric,107,2-125 ,Johnson TC-10 loader, ,127,149,1100,282,382 hydro,382,482,2-IH 582,682 w/ spring blade,2-782,782D,1282,982,1782 super, and ,2-custom built 582 puller,2-narrow frame pullers,and 1-stock 582 puller
Old 03-08-2011, 07:50 PM
westofb's Avatar
westofb westofb is offline
Default Don't even think of doing that!!!!!!!!!!
Don't sandblast fiberglass parts, the sandblaster in a matter of seconds can bore a hole clear through you dash part, cause the fibergalss fibers to protrude from it (looking kind of furry). Just prep with sandpaper, if it is in good shape you could just use a scotch bright pad to give the paint a tooth to bite to.
Old 03-13-2011, 10:27 PM
Okay, sounds easy enough. How about old decals? Heat gun and scraper work for fibreglass too? Thanks guys
Old 03-14-2011, 08:49 AM
young enthusiast the heat gun will also be fine to use. I would not concentrate the heat in a given area for any length of time. Kind of pan it back and forth.
Old 03-14-2011, 09:48 AM
The adhesive Cub Cadet used on there decals is tough! I used a razor blade scraper to remove mine. Did one side, flipped it over, started removing the other and right towards the end, WHAM! The razor blade slipped when the decal broke and ended up cutting my left hand pretty bad! Learn from my mistake!
Nemesis
